It is currently Fri Aug 22, 2025 5:27 am
Post new topic Reply to topic  [ 41 posts ]  Go to page 1, 2  Next
PostPosted: Sat May 18, 2013 9:46 pm
First name: Beth
Last Name: Mayer
City: Tucson
State: AZ
I have some perfectly quartered spruce blocks I'd like to use on a couple of J45s, but wasn't sure if it would be okay structurally.
PostPosted: Sat May 18, 2013 10:26 pm
Boy, I sure hope so, cause I've used it for my last 80 guitars or so....
PostPosted: Sun May 19, 2013 3:38 am
First name: Tom
Last Name: West
State: Nova Scotia
Filippo Morelli wrote:
You don't want the end block's grain to run in the same orientation as the sides ...
Filippo
Guess I'm in deep trouble.......................................!!!
Tom
PostPosted: Sun May 19, 2013 6:55 am
First name: Bryan
Last Name: Bear
City: St. Louis
State: Mo
meddlingfool wrote:
Boy, I sure hope so. Z .
I was just getting ready to type this same thing.
Bryan Bear PMoMC
PostPosted: Sun May 19, 2013 7:07 am
Filippo
Tom
So am I...
Trying to prevent the split that Filippo fears, we plow a vertical groove in our end block, 1" wide, and run a piece of vertical grained hardwood on the inside. That, with the butt wedge, enforces the block and makes it resistant to cracking. And still light!
PostPosted: Sun May 19, 2013 2:18 pm
First name: Beth
Last Name: Mayer
City: Tucson
State: AZ
Filippo
Tom
So am I...
How deep is that groove and inlay, Steve? Any pictures? THanks all for the replies!
PostPosted: Sun May 19, 2013 3:04 pm
First name: Tom
Last Name: West
State: Nova Scotia
Steve: I do exactly the same................................this is getting scary!! Remember the pipe wrench!!
Tom
PostPosted: Sun May 19, 2013 3:39 pm
Beth, I go c. 1" wide, 1/8" deep. I'll look for a pic.
Tom, so who is imitating whom? Or has lightening struck in 2 places at same time?
Just might have to come up to Nova Scotia and see what else works well!
PostPosted: Sun May 19, 2013 3:59 pm
Hey Beth, does this shed any light?
You can just see the groove down there in the tail block.
I like to have the surface of the inlay flush with the surface of the block.
Inlay isn't glued in at this point, but you should get the idea.
PostPosted: Sun May 19, 2013 4:58 pm
First name: Tom
Last Name: West
State: Nova Scotia
Steve: Anything I know I've stole or copied from the smart people...................!!
Tom
PostPosted: Sun May 19, 2013 5:52 pm
First name: Beth
Last Name: Mayer
City: Tucson
State: AZ
Perfect! I get it....thanks so much, Steve.
PostPosted: Sun May 19, 2013 9:51 pm
Appendix brace, eh? Cute, but this is probably more useful than an appendix, no?
Like Tom admitted, this was an idea I stold. When visiting Don Gallagher in the early 70's he showed me his end blocks--done like this--and it made sense.
Actually, the birch ply makes even better sense, but I just enjoy shaping that little chunk of spruce.
And, when radiusing the rim assembly, the side-grained spruce is so well-behaved.
PostPosted: Mon May 20, 2013 9:47 am
I make my own spruce or cedar "plywood" end block, from three pieces, about 1/4" thick, each. The middle piece runs perpendicular to the outer pieces, which run with the rib's grain. Very stable, and when I tried to break(gotta love destructive testing, no? ;) ) one in a vise, using a hammer, I lifted the benchtop from its base, yet the block didn't even crack, so methinks it's strong enough... As lightweight as possible, yet all put impossible to crack. Spruce and cedar is easier to find and more economical than solid mahogany, and the amount of time it takes to rip it to 1/4" and glue it up likely isn't much greater than the time it takes to inlay it like Steve does(which is nice! You do both surfaces, correct?).
Birch-ply will weigh the same as solid birch, which weighs just a bit less than maple, so it is indeed a relatively heavy block. Might appear lightweight, but that's only because it's a small piece.
PostPosted: Mon May 20, 2013 11:26 am
First name: Darryl
Last Name: Young
State: AR
I don't mind a bit of weight in the tailblock......for multiple reasons.
PostPosted: Mon May 20, 2013 11:58 am
First name: Larry
Last Name: Hawes
I'm currently using a mahogany tail block with the grain running perpendicular to the side grain with two small (1/4") pieces laminated on top and bottom that run parallel to the side grain to add strength and avoid end grain gluing surface. So I guess it's laminated but I like the full lamination idea and may go that direction.
Thank You and Best To All
PostPosted: Mon May 20, 2013 1:37 pm
I try to remove weight from everywhere possible, and if anything, I'd prefer a slightly neck-heavy guitar to one that is tail-heavy. With a tail-heavy bias, your left hand is tasked with holding the guitar in position as well as fretting, where if it has a slight neck-heavy bias, the neck rests in the left hand naturally.
Larry, I was doing as you are on my first guitars, as it seemed like a good idea, but over time, a few guitars have developed hairline cracks in the ribs at the tailblock, and I am assuming it's because the tailblock doesn't move at all with the ribs, through the seasonal dimension changes. When I started to notice the problem is when I switched to my 3-layer laminated blocks, and the issue hasn't presented itself since(going-on about 12/13 years now).
PostPosted: Mon May 20, 2013 1:58 pm
First name: George
City: Seattle
Great thread and well-timed for me, as I'm currently looking into making components using woods native to North America. I'm curious to know whether or not people are using these or similar approaches with neck blocks as well as heel blocks. Anyone?
George :-)
PostPosted: Mon May 20, 2013 2:06 pm
3 piece ala Fleta for me in Cedro. half round with tongue and groove construction: smaller top and bottom pieces run parallel to the rim, larger center section runs perpendicular.
a little weight in the tail helps though. too much and the neck lifts, too little and the weight slows down the fretting hand. one needs to balance this imo.
PostPosted: Mon May 20, 2013 2:31 pm
Ah, Mario, you're giving me pause. By that, I just mean that I'm relying on the butt wedge, grain running perpendicular to sides, to be that third part in my "ply". I take it you are recommending inlaying the glue side of the block, like is done on the other face. Not a bad idea at all... if I'm understanding aright. However, I like just as well the idea of a three-ply spruce block which is...as you say...near bullet proof.
PostPosted: Mon May 20, 2013 2:40 pm
First name: Beth
Last Name: Mayer
City: Tucson
State: AZ
What I'm visualizing here is three pieces of end-block-shaped, but only 1/4" thick spruce....2 orienting the grain parallel and one with grain perpendicular and making a sandwich out of the three. Is that correct, Mario?
PostPosted: Mon May 20, 2013 3:13 pm
Two cross grain and the middle vertical grain. That's what I'm reading - I may have to bid my Baltic-ply blocks adieu as I have found I like light guitars; I think they sound better.
PostPosted: Mon May 20, 2013 3:17 pm
First name: Larry
Last Name: Hawes
grumpy wrote:
[b][i]Larry, I was doing as you are on my first guitars, as it seemed like a good idea, but over time, a few guitars have developed hairline cracks in the ribs at the tailblock, and I am assuming it's because the tailblock doesn't move at all with the ribs, through the seasonal dimension changes. When I started to notice the problem is when I switched to my 3-layer laminated blocks, and the issue hasn't presented itself since(going-on about 12/13 years now).
Thanks so much for the info. It does indeed seem like a good idea but my experience is very limited and will defer to yours and will implement the new LarryH laminated tail block program ASAP - with a twist because I have a hard time doing anything exactly like someone else. Thanks again.
PostPosted: Mon May 20, 2013 5:18 pm
Last Name: smith
City: hemet
State: ca
Zip/Postal Code: 92543
I like the way Grumpy thinks.
PostPosted: Mon May 20, 2013 7:06 pm
Here's a visual aid...
PostPosted: Mon May 20, 2013 9:22 pm
First name: Beth
Last Name: Mayer
City: Tucson
State: AZ
Yup, that's how I'm going to do it. Thanks, Grumpy!
Users browsing this forum: Hock and 12 guests
